Hello all
when I export my fly through videos , the video I get does not quite follow the path way I set. I am using the demo version but today we are going to purchase a license , has any body else had this issue?
Hello all
You’ll have to provide more detail. How is the path not followed? Is the preview differing from the exported animation?
Hi Thanks for the reply. No, I realised even the preview is not following the path I set but I think I understand the problem. I am not adding enough key frames. Between 2 key frames I was kind of expecting every move I made to be recorded but I am thinking perhaps that’s not how it works and that I need to add a key frame every time I change direction?
For long straight paths you might need only a few key frames. But when the camera is moving along a curve or changing direction, you should use more keyframes.
