We are experiencing quite some flickering in the glass reflection in the animation when we have set the sun to a low angle. Does anybody had this issue before – any advice or hint? It is not happening when we have a constant time but as soon as we cahnge time it occurs
we already turned of the clouds, wind, checked for duplicate objects - no result
@tommsen , just to make sure could you also record a brief video of this behavior (with your phone for example)? Or instead, you can also quickly render out the scene and share it with me via wetransfer.com or youtube for example? Then we can also see the problem here more clearly.
Hi Demian,
we investigate a bit further and it has to do with the opacity setting of the glass
how can i send you the wetransfer link as this projct is under a NDA
How can I send a private/direct message to someone?
Briefly check out the link above on how to just send it to me via a direct message. Thank you!
