Since the latest update I cannot figure out how to change the video path movement speed.
It used to be in m/s but now I don’t see any option. ![]()
Hey @dvoshart , you can still define the video path movement speed with our “Timestamp” functionality. ![]()
For example, you have two keyframes → Head into the second keyframe and activate “Timestamp”:
In my example, it’ll take 20 seconds to move from keyframe one, to keyframe two. You can of course add as many keyframes as you like and define your timestamps accordingly.
Don’t forget to also hit Apply after you’re done setting up any of your keyframes! ![]()
If something is not entirely clear to you, or in case you have any questions regarding this procedure, please let me know.
Is there a way to slow down the complete movie instead editing every keyframe?
+1
+1
Standard animation software like Bongo is using a relative time line with ticks and finally the user define, how much seconds/frames should be rendered for the setup range.
