I don’t know why but render videos are not supported on my android device. I render in 4K, Max compression and 60fps.
Is there any settings ??
@sp_prajapati , thanks for your inquiry and I’m sorry to hear about that.
Right away, can you let me know which Android device you’re trying to use exactly? It may just be that you’re missing specific codecs on that phone/tablet - Does it make a difference what so ever if you try to view videos in Full HD instead of 4k?
it’s samsung galaxy M21
I need 4k quality to upload pinterest and instagram, because after compression it look hd.
4k renders are not supported by VLC android too. Can’t able to play.
Have you given the other player I’ve linked a try? It at least mentions in the description that it should also support videos in 4k resolution. If that still does not do the trick let me know again, please.
I wish I could at this point assist further, but it also looks like Instagram does not support 4k videos and it’s recommended to downscale the resolution before uploading (or re-exporting in Full HD instead of course).
Feel free to also check out these search results here which go into further detail.
