When creating a video it would be great it you could preview a video at each key frame /a selected time. When rendering out a full building fly through, it becomes very tedious to fine tune individual portions of the video when forced to preview the entire clip.
You can press “P” to start the preview from an arbitrary position.
I had the same problem last that at some portions of the flythrough (a long fly between two key frames only) there was some problematic parts of the scene visible. I very missed a simple slider to move the current position of the camera at the Enscape video editor. So, I could slowly check every position of the camera and adjust/repair the scene. Would it help for you too @mlechowicz , did I understand you right?
Starting the animation per “P” wouldn’t help here, since I have a start, an end key only and 15s flytrough.
Thanks for your feedback - the ability to simply move the keyframes in the video editor has been requested before. I’ve added your upvote and feedback to the topic. ![]()
I’m not sure we mean the same - no the keyframe should be moved, a current position slider for the camera is missing at the time line.
I see! Thanks for your feedback.
I’ll forward it to our developers, as always.
