@Cao_Huu_Chi , your corresponding feedback report which includes log files as well, has been forwarded to our developers for troubleshooting. Thanks a lot for a bit more patience, we’ll get back to you with a solution as soon as possible!
Also, in the meantime, could you also try our latest preview? The one you have installed is a bit outdated already. Further, if that doesn’t help, could you go the Capture tab of your Enscape Settings and set the Capture Resolution to anything below Ultra HD to see if that allows you to render a video?
i also have this problem…what can i do to fix that??? i like very much the plug in and i cant save the video… please help me, i have windows 7 64bit and all requirements enough good to play
Sorry to hear about that - definitely make sure that your graphics card drivers are up to date, and in case that doesn’t work, please kindly send in a feedback report as described here. This will allow us to troubleshoot the cause behind this issue then!
You have the same Error “video recording could not be started” correct?
Also, please kindly attach the files (after putting them in a .zip file for example) with your next reply. If they should be too huge, which is unlikely, you can use wetransfer.com to upload them alternatively.
