I am trying to load around 400mb scene into Project Lavina and after a minute or two of loading it gives me the BSOD,
I am on:
2x RTX 2060 SUPER, studio driver ver. 451.77.
Ouch. Are you using our latest build? If not, please update to it as only it is compatible with the driver you are using.
- Phil
Hi Phillip, thanks. I am on the latest Lavina build.
Anyway the scene loaded when after I tried again, though during the scene loading the screen switched the resolution several times + it was occasionally giving me d3d error.
You didn’t mention - do you have an NVLink bridge installed between your two 2060’s?
I think 2060 SUPER does not support NVLink.
I am guessing the scene is barely fitting in GPU memory, and whether it fits or not depends on what other apps are using the GPU memory as well.
Windows is swapping apps in and out of GPU memory so you get the strange glitches.
When the scene loaded successfully, how much GPU memory taken was reported in the lower right corner of the Lavina window ?
Greetings,
Vladimir Nedev
