BIM view management is complex and relates to 3d views, technical drawings and documents. Using its folder structure the same way should be the norm at Enscape View Management. This way views will be fully integrated. Sometimes makes more sense creating views with BIM software while other times with Enscape.
What stands out Enscape from other realtime renderers is integration and the fact that you don’t need to get out from your BIM authoring platform
Thank you for sharing your thoughts - we appreciate how you emphasise Enscape’s integration with BIM tools. To better understand your idea, could you please clarify a few points?
When you mention using the BIM software’s folder structure “the same way” in Enscape View Management, do you mean mirroring the exact hierarchy from the BIM project (e.g., Revit’s view folders or categories) inside Enscape?
How would you expect this integration to work when creating or renaming views directly in Enscape - should they automatically appear in the same folder structure within the BIM software as well?
Are you primarily thinking of this for Revit?
Your clarification will help us assess how this could fit into the overall workflow and where it would bring the most value.
.Yes, keep the folder structure from views since the view management in Enscape is flat and confusing as one folder does not fit all the info from a BIM project file. One root flat folder is not management. Archicad, Revit and all other BIM authoring tools need to deal with lots of info so they all have folder structure for almost everything.
.For Architects, Integration is crucial because everything is related and linked. So yes, being able to rename and change folder and views in Enscape should be the same as for the BIM software. Same should happen with Enscape materials that in Archicad are called surfaces, they all should be the same and being able to change or rename them on both sides would be the best. If not at least use the info with naming and folder coming from the BIM software.
.WE work with Archicad but it’s the same with Revit, integration for view management is what it’s needed
