Good start, a few things- Sun shadows are too sharp, are you using area shadows?, floor reflections are too strong, some glossy reflections or atleast some falloff would help. Lastly it is a bit dark in there, color mappimg may do the trick but I would probably raise the lighting a bit.
Hi Gastrok,
Your lighting is really interesting & nice. But I’ve 2 suggestions :
First : as you may know Mona Lisa is very small frame. I don’t remember the right size, you must check it. Here it seems 2 meters by one…which is too large
2nd : the erco parscoop sems out of scale. Usually they use little powerfull spot to light things in exhibition, and the diameter is around 10cm or something close I think…
Modeling part:
The light fixture are strange, maybe TOO BIG, try to fix that.
The monalisa picture is out of scale, (compare to the original).
I’will also create framed window.
Rendering part:
The floor mat is really too shiny, try to reduce the reflection level and
use the fresnel option.
Add a wrapper to the floor mat and reduce the GI generate value,
this will avoid this general brown tinting.
Add some backgroud (landscape, sky, or whatever you want)
Use a more fine setting for the IR map.
I think that the day light must contribute more in the scene, use
sky portals instead of using the environement alone.
Or use color mapping to light up the room
use the exponential color mapping, this usually tones down the color bleeding.
crank up the artificial lights but keep in mind that photometric lights are scale dependent
and if you are keen on using direct light shadow to mimic the sun, i’d suggest using them with an angle also you’d have to change the skylight color to match such a sunny sky.
Wow - thanks for all the great advice people! It’ll probably take me a week to work it all out and I may run into some limitations since I only have vray basic. Not to mention the fact that I’m a true noob no formal art, design, or 3d training…hey, but I’ll give it a shot and repost when I think I’ve gotten some where.
