Viewport Activeshade strange behaviour
I’ve upgraded to VrayRT SP1 and it doesn’t seem to me that i ever encounter this problem before.
As you can see in the enclosed file, when i switch the viewport activeshade, the framing of the activeshade is wrong. There’s some kind of offset (and it doesn’t take into account the safe frame), and even with the safe frame of there’s this black strip at the top of the viewport.
When using a regular activeshade window everything is ok.
I would like also to add on more thing : the viewport lock doesn’t work in activeshade viewport mode.
Thanks.
It’s because of the “Safe frame” option; we are working on solving this. For now, you can just turn it off.
ok. Thank you for the answer !
