Hi, I’m having this problem: when on the viewport I have an active camera, if I select any object the view has a refresh and a sort of zoom in, if I deselect or click out the viewport resets.
Do you use 3Dconnection devices like SpaceMouse or SpaceMouse Enterprise? If yes it could be caused by the driver.
Hi, thanks for the reply. In fact I have installed the 3d Connection software, but the mouse is not connected to the pc.
Could it be the software?
May be. The latest driver doesnt contain a fix, which 3dconnection has send me 4 weeks ago. This one fixed this problem. If you want I send you the file with a short description how to install it. Write to info@3d-labor.de so I can answer…
