The setting to start viewport IPR is missing from the dropdown menu in Max 2022 (vray 5.1.2), I only see Activeshade using Arnold.
Any ideas?
Thanks!
Any ideas?
Thanks!
Hi @Franx ,
Does the issue persist if you reset the 3ds max settings?
You can do so by renaming the ENU folder to ENU_old (C:\Users\%user%\AppData\Local\Autodesk\ 3dsMax \<version> - 64bit). Upon starting 3ds max, a new ENU folder will be created with the default preferences. Keep in mind that this would remove any customizations you might have set.
You can then restart your V-Ray menus from the toolbar and see all is good. If not, please get in touch with us through our contact form so we can schedule a remote session and investigate on the spot. Make sure to mention this thread in the email, thanks!
Thanks Nikoleta, I’ll try that
Cool, thanks for the heads up!
