In max 2022, with latest hotfix, there seems to be a problem when using viewport ipr with a safe frame, the rendered image is shifted and not alligned with the mesh any longer
Hi @muoto ,
Seems like its only max 2022 hotfix 1 specific (couldn’t reproduce it with older versions and 5.10.02).
I’ve logged this in our internal system under VMAX-11033 for developer investigation, we’ll let you know when there are any updates on the matter.
Thanks for pointing that out!
Perfect ! works as expected !
Only thing, it would be good if the display uses “exactly” the same config (Lut etc) settings as VFB …
We’re running Max 2021 and even with the latest nightly, the IPR isn’t showing the same as the viewport. Looks like it’s zoomed in
Are you using a high DPI display?
Hi Vlado,
Yes I am
