viewport issues
how does everyone see in their viewport, a nice even lighting that shows all surfaces without have black dark surfaces and some light or material showing?
i’ve set the “active viewport settings” a thousand times to 2 default lights, it always seems to go back to 1 on the next viewport or project.
i’ve put up with this for years now. something changed a long time ago and i started having issues.
is it a renderer thing? or 3ds max thing? i hate to use the area forums so figured i’d ask here.
thanks.
Hi, thanks for posting.
Unless you have enabled Viewport IPR it is a 3ds Max thing.
Try to switch your viewport shading mode
This is now V-Ray IPR looks in this scene:
https://ftp.chaosgroup.com/support/screenshots/3dsmax\_2024-02-09\_13-15-12.gif
I always use Standard with Flat Color shading, and turn off all the bells and whistles, like progressive skylight, shadows, AO, … Anything else and 3ds Max is either slow and too dark, etc, can’t see what I’m doing when modelling, texturing or placing assets. I switch a lot between Flat Color and Clay mode too. For big archviz scenes it’s the only way to go I feel.
There’s a script here you might try:
Maybe see if it works then save it to your startup scripts?
IPR in viewport like that is very cool. however, i usually put IPR window up on 2nd screen for others to look at when we’re jamming.
woa that script looks like exactly what i need. although sometimes it doesn’t work.
flat color seems like a good quick option to change to. i might switch to that, although it’s a little “bright” when i have a lot of light materials ha (white ceilings/walls)
i never understood why we can’t just set and forget.
also, wonder if it’s worth having a 3ds max users sub-forum to discuss things like “what do you do?” or “how tos” even if it’s not vray related. a lot of forums i see just aren’t that great, but when i’m stumped i do go to the autodesk forums ugh.
Hence the only reason I use facebook is the stack group there. Best place to get an answer imho concerning 3dsMax. stack | Facebook​
