hi there, i face a strange problem. i work on an interior scene. for hours everything works fine, suddenly i see nothing more in the top and the bottom view. zoom extends, scolling and zooming in and out brings no solution. i even see no grid(also when i uncheck it and check it again). also tried to model a box in the top view, i only see the lettes of the axes of coordinates of the new object - and nothing else. when i change to any other view (than top or bottom)in the viewport everything is ok.
I’ve had this a few times. Select any object then zoom extends to selected object. twice. then deselect all and zoom extents. This works about 90% of the time. Other 8% I restart max and that works. Remaining 2% some good swearing sometimes helps
check the scene extents of your objects if the above fails, saw this when and imported ACAD spline had a bounding box that was too large for Max to cope with…
I had the same problem in the past for these reasons:
1. I had some garbage 389km away from 0,0 and was working in mm. I deleted garbage and all was fine.
2. I had some null objects in the scene (objects with “0” vertecs so you can’t select them. Deleted them and all was fine. There is a script to search for null objects floating around)
3. Vieport config got screwed. Select any other viewport config (like, if you are in 4-viewport than select 3-viewport) and that should fix it.
4. I had a gremlin im my video-card. I removed it and all was fine…
hope this might help
zoran
thanks for your replies. i tried all of them - out of that one with the “0” vertecs" - which would have been my next step, and had no success.
to find out if a “0” vertecs object could cause the viewport problem i deleted all objects in the scene, and the grid in the top viewport returned. then i made one “undo” and all objects are seen in the top view again.
next i will try to find out what caused the problem - “0” vertecs or issues with my graphic card. as i face the problem in different scenes i think it is the gc.
Sometimes we get display problems if some of the VRayProxies from the scene point to a vrmesh file that is no longer there.
For your description it doesn’t seem the same display problem, but it’s worth a try to hide all your proxies to see if the problem persists.
thanks for the hint codi, i have no proxys in my scene.
@zoranm: do you have a link fot the desriped script?
Don’t have a link but script is called Object Inspector by Piranha-Bytes. You’ll probably find it at ScriptSpot or google it. I was using it for Max9, but you can do inspection yourself through summary info. Just look for geometry with 0 verteces, select it by name and delete it.
I mentioned script only because I sometimes have thousands of objects and script does it faster than me looking through primitive summary info.
hope this helps
zoran
