Viewport selection render doesnt work on dr?
Viewport selection render doesnt work on dr? When i use the viewport selection render and dr at the same time i get very dark stripes, is it a known behavior?
(i have a render but i want to add something more to it, so i add the things and select them in viewport, then select the option to render just that objects, and when i render the image the stipes begin to show)
Which version of Corona are you using? You should be getting a warning leading to this article: https://coronarenderer.freshdesk.com/support/solutions/articles/5000676454
oo ok, didnt see the message, im using 1.3
