Vignetting doesn't work when Glare/Bloom is enabled
As the title says. I can’t see vignetting if I’ve turned on Glare, Bloom or both. I tried even setting Vignetting to an extreme value of 10.0 but still doesn’t work. I see it while Vray renders (progressive) but once the render finishes, Vray applies the bloom & glare and the vignetting I was seeing before disappears. Is this to be expected? For specs please check signature.
It looks either as a bug or as something not supported.
Will add a note about it into our system and will keep you posted.
Thanks for looking into it. :slight_smile:
For some mysterious reasons this bug disappears when rendering with Subpixel Mapping ON.
This could be used as a temporary workaround until being fixed.
Thanks for the tip! So it’s not unsupported feature. In this case hopefully it’s something easy to fix.
I can happily confirm that with Vray 3.5 Beta this problem seems to be fixed!
