Villa 3
Hello guys,
I would need your advice to make the images even more real and special.
Thanks for your help.
C4D-Corona PS
Andrea
small project update …
Andrea
Hi Mutilo
First and foremost I am no pro myself I would just like to give some insight as to what I have learned in the past year or two
  1. As a beginner it can be quite challenging getting a scenic background correctly, I zoomed into the projects as much as possible so that there is little edges on the side, which one can fill with a tree or two
    2.The metal louver system does not look like metal at this stage - it just looks grey - there is excellent tutorials on corona Youtube channel that will show you metal texture , also with 1.7 there is good premade metal materials
  2. Add corona round corner on practically everything even if it is just small amount
  3. Vegetation - ensure you have translucency on all vegetation and have the sun shine from the back a bit , really brings out the translucent leaves and gives an overall more realistic feel.
  4. Try a potplant or two , maybe at strategic places next to louver
  5. The little go cart looks a bit random and in the way of incoming cars in the driveway, I like it, maybe just somewhere on the grass
  6. Instead of having the car perfect under the shade having it maybe half way out of the scene , like it is driving to someplace , if correctly placed it will in effect still be covering that space
  7. The paving material needs a lot of work, really concentrate on the bump and normals at this stage again it is just whitish
  8. The little trees are also way to random , really think how someone would consider garden layout. Maybe bunch them up in a corner a bit with some white flowers for contrast, but as it is no one will really plant those Buccus in such random place on the grass
  9. Opt for a 2/3 sun shadow , where you have 2 parts sunny and one part in shadows
  10. Volumetrics can do wonders for a realistic hazy scene , also good tutorials on corona youtube
  11. You can buy ready made scenes with excellent lighting from the boundary store , it contains awesome materials like glass and even vegetation. Copy those materials and use it. Delete everything in the scene paste your in scene in there and voila perfect light ( will work most of the times )
  12. Siger shader has an awesome preset material library that can practically cover most basic scenes, they are even procedural so UV’s wont even pose a problem
  13. Go on architectural sites like Archdaily browse around until you find a similar looking design as your house and see how it was photographed, copy that 100 % in angle and light and in overall vegetation.
  14. The most important advise I got from Tomorrow render firm … REFERENCE, REFERENCE , REFERENCE. with this render then where did your inspiration come from and if you say from your head and heart , as beginning artist that is a big mistake as we dont truly understand what beautiful is.
Remember I am a beginner myself and my portfolio not necessarily any better, but I try and implement the above and always stay open to critique
Hope the above helps : )
Thank you so much for the advice. I can not wait for them to test.
in fact with the material of the leaves I find myself in difficulty because there are no crown tutorials for c4d.
I too am a beginner and these renderings are just a side dish to the work I do, although I would like to put them first as work.
Thanks again.
Andrea
