I want to share with you renderings made with 3dsmax and corona.
Designer / Architect: Andres Remy Arquitectos, Alejandro Peral for photos references
Personal / Commissioned: Personal Project
This project is based on reference images from Andreas Remy Arquitectos. It was interesting to explore the architecture plans and drawings,
as many of them were different than the final versions of the house. It was challenging to match 3D model without any exact dimension,
but this was the fun part as it gave me choice to modify and be part of it.
Images and plans I found on the:
Also interesting field of study for me was photographer Alejandro Peral, who inspired me (beside architecture) to make 3D model and visuals of the house.
Vetical image hands down - amazing. Other two beautiful but those lense flare star glow are not going together very well.
Is there a chance you would tell did you use HDRI or corona sun+sky? And if you did use HDRI did you kept its backplate/background for the image or did you replace the background in post?
Plugged HDRI map into corona environment slot. And then created a Corona sun and aligned to the hdri sun.
This is understandable if you need sharper more pronounced shadows.
But you can get those sharp shadows with hdri as well right? If its a sharp sun hdri, you should get nice shadows. I do not understand why did you put an extra light - SUN into the scene?
Because if you want a warmer lighting you can color grade the hdri and it will work as a warmer lighting. And then there is post production.
Can you please explain why did you choose this lighting setup. HDRI + SUN? And not only the HDRI?
I used this combination (HDRI +SUN), mainly because of the shadows.
HDRI couldn’t give me nice shadows of the tree to entrance patio, so I involved the SUN to combine both.
