this one is connected to the previous bedroom post.
Here is a living room, there will be 2-3 mode shots, we may equip it more, provided the clients budget allows that ![]()
Looks good! That ceiling light seems to be hanging from nothing. Is it touching the ceiling? You would see a contact shadow, no?
Hi Bobby its hanging there by 4 quite visible strings. The ceiling fixture is place approx 0.5 mm below the ceiling by its rim and the inside goes directly into the ceiling so unless there is nothing wrong with vray, it shoudl be computed correctly. There is quite a lot of bounce in the room and also the light emiter sends light above too thus killing any possible shadow cast from the sunlights direction.
Beautiful.
Thank you! ![]()
Nice. How you lighted the scene? ![]()
Just vray sun and skylight portals Jirko ![]()
vray sun set to 1.0 and no tweaks to skylight - everything on default except the sun size
