Sharing with you our latest project that is under construction in Beirut, Lebanon: a SPA in an ancient vaulted basement
In the vaulted basement, the one meter thick walls completely isolate the space from sound and
light, creating an ideal setting for an intimate earthy Spa. Walled and floored with reflective
tadelakt plastering, this elemental space emits feelings of being cocooned within an age-old
shimmering cave. Centrally throned under the cross vault like a delicate treasure, an emerald
pool entrancingly steals attention with its bright aura glowing all over the smooth surfaces of the
entire spa. Two solid Carrara marble slabs retire as massage benches behind this majestic pool.
A custom-made American walnut wood sauna, a steam room and showers seamlessly blend
into niches within this environment. Breathing more life into this vault, flickering candles
illuminate the space with a solemn and animated light. This light-play, the luminescent pool and
the shimmering tadelakt choreograph a gently stellar and grounded ambiance.
Software used: 3DsMax + Corona Renderer
