Hi, this is an old personal project i’m updating it these days, and i wanted to render it with corona this time, so i’m working on its materials and elements etc and this is the first test.
I did use forestpack here since it’s compatible now and it does a pretty good job, only thin is the noise still appearing even after about 3h30 of rendering ( second image ) for an exterier scene.
There is also some weird few white dots even if i used only an hdri map with no additional light.
I agree, these are with no post and i don’t like the contrast in post processing of corona, will be applied with color correction in photoshop, also need to test more sky versions to see, i’ll do also a night version with light, i think it will give more beauty with the outside lights on grass and pool.
Just wondering if there is a possibility of calculating caustics to add more beauty to the pool ( isolating the pool and sun light to calculate it ), any tips in parameters?
Renderer: progressive photon mapping, or renderer: Bidir/VCM set to VCM mode should do it, if your scene is not overly big. You just need to tweak the photon radius parameter.
This is a night version i’m working on it to test lights and materials, render took about 1h for a 1280x720 with PT-HD cache using debug mode and sampler 5D High-D + PRNG
i’ll remove reflections from the short grass and edit the interior lighting, pool is ok i think i like it even without caustics, but i’ll work on caustics at the end to see the result.
Maybe palms need some lights from the bottom.
More variations of plants and flowers must be here i think
agree with you because it’s still in progress with no post and materials tweaking,
the worst thing in the story is : my max file is corrupted after making a copy of a palm, and i didn’t turn on autosave O_o but i have a two days old scene …
Anyway, maybe it’s a good thing so i can make it more acceptable, i will keep it until the blur bug is fixed.
