The “visible in mask” option does not work.
Not in the CompositionTag and not in the RaySwitchMaterial.
What I’m trying to do is this:
Any way to do that in C4D at the moment ?
I can confirm that this does not work with the compositing tag. Moving into bug reports section…
Hey guys,
I encoutered the same problem with disabling “visible in mask”. The solution is to open the right material and under advanced settings you will find uncheck visible in mask.
Good luck.
