visible in reflection
A simple VRayLightDome and 2 reflective spheres. Turning of “visible in reflections” in the spheres does not work as expected!?!?
Any idea why this happens?
VRay Next hotfix2, and Maya 2018
This is a known issue. The fix will be included in the next hotfix.
Thank you for reporting it.
Ok, thanks… will be waiting for it :slight_smile:
Did this fix get released? If so, what version?
It seems to be working fine in Next Update 1. Can you try the newer build and let us know if everything works correctly?
