Visible to Camera object property misbehaving in RT
Objects with unchecked Visible to Camera property show as black or just some artifacts in RT while with Vray Advanced they render OK ( not render, just cast reflections, shadows etc ). Is there currently any solution to get it to work ?
I don’t have RT but could it be the Max Transparency Levels? Global Switches, Materials.
Thanks,I tried different Max Transparency Levels as you suggested but the problem persist.
Do you have an example scene for this? Seems to work fine for me on a simple test here.
Hi Vlado,
It works fine on the simple scenes here too.
I can give you the scene file I was working with but it’s quite large - is there a way to upload it for you somewhere ?
( the problem repeats on more complex scenes )
Regards,
Jarek
Yes, if you email us to vray@chaosgroup.com we’ll be able to get you info to upload this on our ftp server.
Vlado - the file has been uploaded to the FTP I got from Zori.
Regards
Jarek
