Visiblity problem after scene conversion
In vray rendering everything is OK. Orchidea flowers actually are BEHIND table??? it is some problem with visiblity, but i checked all materials, alle properties (visible for camera or reflections etc) and everything is correct. All face normals for this table is ok (i checked in EDIT MESH in 3d max). What’s wrong?
What Corona version are you using?
Alpha 5
ok, the geometry processing changed a lot, so the problem is probably not in the latest version, but can you upload the scene just to be sure - Renderer for architectural visualization - Corona | Chaos ?
Keymaster - give me a hour. I have to prepare this scene because it’s commercial project and i will try to reproduce this bug in new scene with the same furnitures without commercial enviornment.
I have big problem with this scene…really big…If i TUNR OFF layers with books than scene is rendering OK.
i have no idea how to prepare this scene for you to upload (280 MB - huge scene). I will try now to check which furnitures or books are making bug and will try to prepare scene in simple version (to 280 MB).
And one more picture - this time GLASS ROOF is changing visiblity…
you can just split the archive in total commander into several smaller ones
What is a max files size to upload?
ooo i see 128 Mb :smiley:
I remember some problems with frozen/hidden layers in A5. Does this still happen if you merge everything into one layer?
maru - hmmm. thats good idea - actually i’m exporting whole scene for Keymaster and my computer if busy, but give me few minutes . I will try to use your knowledge:)
Keymaster - i uploaded file “Hall_Problem.zip”.
I tried to make all model in one layer (like said maru) - but bug is still there :frowning:
try to render with override mat, just to make sure its not material, texture, refraction issue
Vado - i made test with white override material - bug is stil there:(
WOrks correctly in latest daily, you can test it to be sure after I make new build
2014-03-02 - this build works fine?
no, use the latest one with todays date
