Vision rotated in zenith view
In sketchup 2019, if I set the zenith view, in Octane i see a rotated (180°) preview.
This happen when I use synchronized view and when I don’t.
When I change the inclination of view all is normal and synchronized.
Hey @happymilk_2 , this behavior is expected due to technical reasons. If we would allow the synchronize view function to 100% control the output in Enscape, you could end up with a view which shows the project upside down, which is something we don’t want. In this case, Enscape flips the output to avoid this. You should be able to easily resolve this by simply tilting the SketchUp camera just a tiny bit. :slight_smile:
Hi Demian,
Ok, this is not a big problem. Only a strange thing.
Thank you for the technical explanation :slight_smile:
hmm, ok, I can’t argue against the mentioned technical limitations.
Nevertheless, just a small note: When we choose the Top View button within Sketchup we will get kind of floor plans or site plans. These are so very important view settings which are usually necessary for almost every project! I think, at least this one setting should be possible without any tilt fumbling :wink: - unfortunately Enscape´s view jumps 180° already here…
+1 to eliminate this (elsewhere never seen before) behavior :slight_smile:
