vista sp1
anyone installed sp1 for vista 64 yet?
just wondered if there were any issues before taking the plunge.
cheers!
Don’t do it! :slight_smile:
Actually I haven’t tried it yet either, but I haven’t heard a single good thing about vista 64. I love XP 64 and will try and stay here as long as possible…
EDIT: Oh, sorry. I misunderstood. You’ve already switched to Vista. It works? Any problems with Max, Vray, or network rendering (DR or BB)?
euhm yeah, i also have read everywhere sp1 is not good, very slow and is causing loads of people allot of trouble…
I use the vista x64 on my comp home, runs very stable and fast. my thought is if it works then dont change :slight_smile:
been using vista for a few months now and it’s been pretty much fine although i haven’t used DR…
only issue is having to run viz as administrator in order to get vray to work at all, although it’s more of an annoyance than an issue.
Hi. Running Vista 64 for 3 months on 3 machines, installed Vista 64 SP1 a few days ago, using DR, absolutely no problem with MAX 2008 64 and VRAY 1.5 SP1.
Also here. I’m with 2 pc with Vista Ultimate SP1 x64 and all running fine, since one month ago.
Workstation with Vista x64 since 3-4 month here, MAX 7, CS2 suite, DR BB etc. No problem at all except that it doesn’t support a 10 years old laser printer…
The only big issue is that OpenGL is not really supported (emulated trough Direct3D if I red well) but who does still use opengl in max anyway ?
SP integrates the cumulative updates, so no need to get it if you already have vista I think (and if you did let it make his updates)
i installed sp1 for vista64, it solved some hardware issue with energy saving mode, otherwise i didn’t notice a difference.
max & vray still work, even DR with 32 bit nodes works.
:slight_smile:
would like to say i have SP1 installed, but for some stupid reason it doesnt offer SP1 patch in Windows Update :(((((
have searched through all the possible forums, have gone through all the steps that i should have taken to make the update possible but still no joy :frowning:
will have to reinstall the comp i think as ive been waiting for SP1 a long time…especially because of fixes in energy saving modes…
other than that, vista is running just fine, actually it lets me use more memory than XP…
this is a very usefull page that i use :slight_smile:
http://www.winvistaclub.com/t1.html
cool. cheers for all the responses. looks like it’s a go-er then!
cheers!
Installed SP1 the other day, and everything still seems to work fine.
I have been using Vista x64 with max and VRay for half a year, and really I can’t understand what all the complaining is about. Everything works fine, and I’m starting to prefer Vista over XP now that I’m used to the changes.
the first time i saw vista (32) was on a way underpowered dell notebook. the aero fx lagged, the “user control” warnings drove me crazy and i hated the way it locked me out of everything, when i tried to get rid of the pre-installed useless dell stuff.
and it used up all of the 1gb memory, took minutes to boot, etc, etc…
i recently tried again with vista 32 & 64 on more powerful machines, with 4gb ram, a clean install, and i don’t hate it anymore.
actually it runs pretty smooth. you can switch off the stupid warnings. some stuff rocks, like the shadow backups, the resource monitor, and yes, the start menu and UI is nicer too. i still don’t like the mess with the virtual program folders and user folders, but i understand that it’s important to prevent (most) people from doing stupid things with the system files.
We have had 2 vista 64 machines here for about 6 months, they are performing better than any of our others. I felt that a little tweaking was needed out of the box to get it to perform the way I wanted it to(I turned off superfetch to control RAM usage a little more predictably, changed user account settings to get rid of most of the nag boxes, and also disabled the aero interface).
I dont with 3d/arty stuff, i was using it at home for ages.
But NEVER get vista if you like to make music on your pc. the second you try to get a bit creative with software/plugins or add hardware it’ll bite you in the ass.
Got Vista 64 Ultimate for 8 months now and it’s purrrrrring like a kitten!
No problems so far with MAX 2008 and Vray 1.5 SP1
Also switched off user account control. (No problems so far with Vista SP1)
OK so I have 2 hardware issues with HP stuff. My Scanjet 5200C doesnt work with Vista 32 or 64 so I wanted to get one of those all in one jobbies. Which brings me to the next problem. I was looking at some of the supposedly new HP Business officejets print, scan, copy and fax (sorry no coffee) and what amazed me on HP’s website is that for this “new” piece of hardware there is a footnote that says “…may have limited functionality under Vista”. I mean what the crap is that all about?
that’s interesting, because i’m playing around with music software too.
i tried ableton live, NI kontakt, stylus rmx, and a bunch of vst plugins, they all work 100% right with vista64, as with winxp.
one thing that doesn’t work of course is my old m-audio delta card, because there are no 64bit drivers for it. the presonus firebox got drivers, but the latency is higher than i’m used to on winxp.
the indexing service (and probably others too…superfetch, etc..) is causing pops&clicks, as expected. background hd activity and realtime DSP doesn’t mix well.
but from the OS side i see no problem, i blame bad performance on the half-baked 64bit hardware drivers. but i’m still in the testing phase.
i’m pretty positive that for music making and realtime audio processing, vista 32 behaves just like winxp, but switching from xp to vista 32 wouldn’t make much sense, of course.
I installed it on all just a week agao computers. You can download the whole Update it distribute it.
It changes in my point of view near to nothing. Well Vista starts a little bit faster…
Just FYI - another vote for SP1 being worth it. Installed SP1 on both my Vista 64 boxes, no issues so far, and fixed a few nags.
is anyone running nvidia raid boards with SP1? we’ve been hanging off installing quicktime because it corrupts the raids, but wondered if SP1 had fixed it. (there’s been so many conflicting fixes, we’ve just steered clear of QT for the moment on these machines)
yes. the quicktime-raid thing is realy scary. I uninstalled quicktime to only use the codecpack. and it works OK..
