I have two different perspective views saved in my project. They are on the same view template, except this template does not lock overrides for Links OR Filters. The two views, thus, have different values in those categories. View 1 is showing the link, View 2 is hiding it. View 1 has no filters, View 2 has filters.
Using the Enscape ribbon to switch from View 1 to View 2, I’ve experienced a crash where View 2 actually inherits the filters and view settings from View 1, and moments after this Revit hangs up, and my computer actually compleletly freezes. I had to do a hard restart by holding down my power button. 8| I’d be curious if you can re-create the issue. I will send my log files when I can. I’m using Revit 2016 Update7 and the second to last Enscape version.
