There’s a couple of pain points we regularly encounter when working on larger projects, especially with multiple users, in relation to visual settings and managing/updating views. I have the following feedback/requests:
Expose Linked Presets And Sun Position
In View Management all Views are shown, as well a small icon signifying if there is a preset or sun position applied. However, the only way to actually know what preset/sun is applied, is to click the edit button, which then transports you to that view and forces Enscape to load it. This is a huge pain point when we’re managing 30+ views and we need to confirm which views are which using which settings.I’d like to propose that the preset is displayed (I’m not a UI designer, but you get the idea)(hopefully):
Being able to tell at a glance what the settings are would be a big improvement
Allow View Edits Without Loading The View
Similar to the above, in order to rename a view, or change the preset, the ‘edit’ button has to be clicked, which forces the view to be loaded, then the changes are made, then the view needs to be resaved. All because I just wanted to rename the view. I would much prefer if there was an edit button next to the View Name itself, that just edited the name without having to load the view. Similarly, I’d love to be able to swap the preset to another without having to load the view e.g. with a drop down (again, not a UI designer so this is for functional intent only
Update/Overwrite View Button
Despite years of Enscape use this one still frustrates me all the time. I open a view, I decided I want to tweak the angle, so I move around slightly, find the perfect spot, and then realise I forgot to press ‘Edit’ button first. So now I have to create a new view, or I have to click ‘Edit’ and lose my changes and revert back to the original position. Surely it would be easier to have an ‘Overwrite’ or ‘Update’ button, so that I can just take the current view and resave the position? If the presets and sun settings and name are handled as I proposed above, then the current ‘Edit’ button wouldn’t be needed. That space could instead be replaced with an ‘Update Position’ icon and tooltip if need be: “updates the position of the saved view to the current viewport”. -
Visual Settings Presets
This is another one that causes havoc on jobs, especially with multiple team members and varying levels of experience. But put simply it is just way too easy to be in a view and be editing the visual settings and not realise you’re editing a preset. I think the ‘Presets’ sidebar should be exposed by default always, and in order to change settings you have to physically press an edit button next to the preset.Or, even better, something similar to Revit View Templates needs to be implemented whereby if a preset is applied then the visual settings dialog is just greyed out (because the settings are being handled by the preset). In order to adjust the settings of a preset it’s a separate ‘preset settings’ button/dialog, that more or less presents the same in terms of the settings window, but forces users to recognise they’re editing a preset and not just editing the view they’re currently in.
Perhaps it’s because I’m heavily used to the Revit View Template workflow, but it’s potentially one of the areas Autodesk managed to do reasonably well, and I think a similar setup for Enscape would be a huge improvement. Revit View Templates also allow the template (aka “preset”) to have control of limited settings only, if the user desires. If applied to Enscape it would mean I can create a preset and include all the Image Correction settings except for Color Temperature. I can then assign that preset to multiple views, but go into each view individually and tweak the colour temperature, without having to create 5 different presets just because that one value changed. Or I could exclude the ‘output’ settings from the preset, and be able to render out different resolutions without having to maintain multiple different presets.
That last point may not be very well explained and possibly deserves it’s own post and proposed UI screenshots to convey the intention a bit better, but I really think it would be a masssive step up in terms of view control and UX. The one thing I know for sure is that current implementation is frustrating (at least for me and the people I work with).
