I’m able to install the EGZ beta materials like normal, and can create the materials just fine. But when I shut down Viz and re-open the same file, it says its missing the .dll for the materials even though its still there. Then when the file opens the material does not work, but it will still let you create new EGZ mats.
I’m sure its not a Vray bug, or EGZ bug, but has anybody else had the same problem with VIZ 2006 and found a solution yet?
This sounds very strange.. I don’t have VIZ so I can’t check if they work as intended in Viz 2006. Does this happen all the time? Is VRay assigned as renderer when it happens? Do you start Viz by doubleclicking the file, or do you start Viz, and then open the file?
