vizpark omnitiles and distributed render
Does anyone have success with omnitiles in distributed render?
Because I do not.
The render node does not recognize the omnitiles pattern file.
Is there an idea?
Try using “Transfer missing assets” option. Also, make sure that you have installed the omnitiles plugin on all render nodes and all nodes have access to the same omnitiles pattern files. I will try to do some test, meanwhile you could try contacting Vizpark tech support as well.
We made few test and DR seems to work fine. We installed Vizpark omnitiles on two machines and activated the license for both of them. Also we managed to render a simple scene using DR and the omnitiles presets.
You could doble check that you have installed and activated correctly your licenses for Vizpark omnitiles for all of your render nodes.
