I had a couple questions about VizPark’s Real Grass and was hoping I could get some clarification from the Corona pro’s.
First, when I open a scene I get this message:
PTpDTPO.html (7.4 KB)
If my gamma is set to 2.2, when I import these bitmaps I should override to 1.0 correct?
Secondly, the materials seem to be made differently than anything I’ve read or watched about Corona. As you can see they use a Fresnel IOR of 999, and a refraction level of 1.0.
JDZh7eP.html (7.4 KB)
Is this a correct way of doing it? Or should I be adjusting them? Thanks for the help in advance!
EDIT: Not sure if the images are showing, I’ve added them as attachments as well.
The output gamma basically shouldn’t matter anymore as it’s automatically overriden, i.e jpeg gets saved as 2.2 from framebuffer, .exr gets saved as 1.0.
That is, if you use 3dsMax version that has this feature (2015+ ? I don’t remember since when…).
The material is plain wrong. Maybe the idea was to have really “fast” rendering shader ? Whatever was the case the result will be bad looking.
Thanks for the reply Juraj, I will see what I can do about the grass. Much appreciated.
a quick fix on this ( but by no means 100 % correct )
Is just drag the diffuse texture into the translucency slot and set to about .5 ( play around a bit )
Drag the exact same diffuse into the glossy and bump slots and set reflection to full
Play around with output to get desired effect , but it will completely change the look
Like evermotion vray tree models, they also tend to put a greyscale image in the translucency slot and
that what makes the whole plant or grass grey and ugly
Imho they are quite well modeled and if textured and scattered correctly can look very good
Edit : No refraction and IOR at 1,5
Thanks for simplifying the process for me, Jadefox.
I really like the RealGrass bundle, especially the grass fields they have, but I knew from all the Corona tutorials that there was something up with the materials.
