volume fog
is there any way to do this? https://www.youtube.com/watch?v=RbOKWhlxkQM
0:14 global volume distance from ground?
My approach would be to apply a gradient on the volume material and adjust the settings to get something I’d be happy with. :wink:
Thanks beanzvision, can you send a scene?
Sure thing :wink:
low_fog.c4d (283 KB)
This is quite cool, but I’m intrigued by the idea of a “distance from ground” function. Is that doable in C4D or only a 3ds Max feature? I would love to have fog that hugs the ground, whereas this seems like a general workaround to blend fog across the flat top of the volume box.
There is the native Proximal shader, which plays a similar role to the Corona Distance shader in Max. Things I noticed on some quick tests a while back:
  • It works only on vertices, not smoothly on the boundary of the selected “distance from” object. Can kind of smooth it out by playing with the distance and intensity
  • It only works with editable objects (so, a parametric sphere won’t work; also things like Volume Meshers and SDS didn’t seem to work)
  • IR doesn’t update when the “Distance From” object in the Proximal is moved, though it does if parameters are updated or if the object painted with the Proximal shader is moved
  • I can’t see a way to add noise into the distance parameters of the Proximal (useful for ensuring there aren’t hard, geometric shapes in the Inside Volume result, e.g. for a cloud shape). Maybe it could just be multiplied with some noise map in another node?
I’m trying to create the steam on top of a jacuzzi at night. The problem is I can’t get the volume material to fade out. You can see in the screenshots that the steam stops somewhat abruptly at the outline of the volume mesh. I tried a gradient yellowish fog to pure white and also a texture with a gradient to 100% transparency. The texture approach looked even worse.
Can the volume density only be controlled by the “absorption distance”? My distance is set to 40 cm, If my mesh is less than 40 cm the volume should be “clear” correct?
Does anybody have an idea what else I can try to fade out the “fog”, besides “painting it in” in PS ?
Thanks in advance.
On the Absorption Distance - with a value of 40 cm, after traveling 40 cm through the volume, the ray will have the color specified in the Absorption Color; between 0 and 40 cm it will already be graduating from nothing to the Absorption Color though, so will not be “clear” other than at a distance of 0. Raising the Distance well above the 40cm will make it fade out more. As an alternative, or as an additional effect, you can vary the Absorption Color through a Corona Distance map (Max) or Proximal map (C4D), so that at a certain distance from a certain object the Absorption color is pure white (which counts as zero absorption, that is, no effect).
Hi Tom,
thanks for the explanations. I already tried to wrap my head around the Proximal shader, but I can’t figure out how to use it in this context. Can you point me in the right direction?
“that at a certain distance from a certain object the Absorption color is pure white (which counts as zero absorption, that is, no effect).”
How does the volume material get mapped inside the volume mesh? I thought I might be able to achieve the fading with a gradient to pure white, but that doesn’t seem to work.
It doesn’t get mapped inside at the moment, just on the surface - there isn’t an “inside mode” in the Corona Volume Material in Cinema 4D yet.
On the Proximal, things to keep in mind:
  • It works only on vertices or edges, not smoothly on the boundary of the selected “distance from” object. Can kind of smooth it out by playing with the distance and intensity
  • The distance parameters are the very odd %, rather than actual distance units
  • There’s no control for what happens inside the “distance from” object versus outside of it (seems to be just raw distance from vertices)
  • It only works with editable objects (so, objects that are still parametric won’t work; also things like Volume Meshers and SDS didn’t seem to work).
Very quick Proximal scene attached, but just using Diffuse (altering the diffuse color of the cube based on distance from the edges / vertices of a plane).
Proximal.c4d (341 KB)
I still think that a gradient in the absorption slot might work. ? Attached is a quick and nasty scene.
Grad_vol.c4d (338 KB)
Yep, gradient is fine so long as you aren’t having the fog hug a surface that isn’t flat (such as a ground with rises and dips in it, and you want the fog depth to follow that rather than be a preset gradient).
Thanks Tom and beanz,
will give that proximal shader another try.
With the gradient you still see a “hard” outline at the mesh edges. I tried round, irregular shaped meshes and different gradients (circular etc) and also different mapping, nothing really worked.
That’s why I was hoping, the volume mat could be 3D mapped inside the mesh.
Yep, that might be a drawback of the fact that it is only calculated at the surface, and the Proximal shader wouldn’t really change that. Should be less obvious with your “steam mesh” though as it has an irregular surface (either with gradient, or Proximal).
It also looks like the Volume shader might not like the Corona Shared Shader, at least if Proximal is in the chain of nodes somewhere, so watch out for that.
You could chamfer your edges to eliminate that. :wink:
Hey beanz,
did you see my steam mesh? No edges to chamfer…
It’s what Tom said, the problem is, it’s only calculated on the surface.
The proximal shader also didn’t do the trick. I just brushed in the fade in PS.
Any plans to give the volume mat a “inside mode”?
Does anyone have more recent success with creating noise, or graduated volume fog? I am beginning to think that Corona for C4D needs to have the “Corona Distance Texmap” as shown in the linked tutorial (the C4D proximal shader is just not up to par)
https://www.stateofartacademy.com/en/corona-renderer-tutorial-volumetric-fog/
