Volume glass and mat sticker
Hi, a candle glass with grey volume and branding label mat sticker.
Sticker coming black… it should be mat white, any idea how can I fix sticker…?
Sticker effects with glass volume, if I do it white sticker comes fine.
Thanks.
How are you applying the sticker? Is it a decal or a stacked material? Can you share the scene at all?
Try and copy real life is always a good suggestion. Is the label a separate object or is it a poly selection of the main glass?
If so you’re mixing the refraction on the glass depth. It should be a separate label on top.
Use the split command to make a new poly object and apply your label to that instead
sticker is separate polygon.
Thanks @ davetwo, its separate object.
have to tried glass with volume…?
thanks.
if I reduce glass volume… its fine but I need dark glass.
here is file.
thanks.
label.zip (1.38 MB)
If the sticker needs to be white as mentioned, do you really need refraction on it?
no… not white, should be mat transparent.
like this.
Sorted and its perfect…!
Care to share with others how you resolved it? :smiley:
ahhh… sorry.
Here is little trick, same file same setting, just reduce the Fraction to 95% of label material.
If increase glass volume, more dark… set label material fraction to 90 / less or more.
What is science behind it… no idea…!
thanks.
