Volume Grids with Volume effects
Hi All
Im not sure if theres a work around or if this is just a limitation with Volume effects.
Theres a blue halo inside the volume grid box if volume effect in corona sky is enabled. I know iv gone agreesive with the volume effect scale but is there a way to remove the blue halo without reducing the scale? See screenshots, 1st image with volume effect, 2nd image without volume efflect.
Cheers!
Neil
This seems to be the only logical fix I could find, also works with volume grids.
I was able to reproduce this issue and have logged this in our system to be further reviewed by our devs.
(Report ID=CMAX-1262)
This issue has been fixed in the newly-released Corona 16 preview build and the fix will be included in the final Corona 16 release: Chaos Corona 16 for 3ds Max - Previews (Daily Builds) Changelog - #4 by AramAvetisyan
Please try it and let us know if everything is working as expected. Thanks!
