Couldn’t find a topic about this:
Is VRay able to render standard type Max environment volume lights? I don’t see my projector light beams anymore after switching from scanline to VRay.
Thanks ‘n’ cheers,
Metin
Thanks ‘n’ cheers,
Metin
Hi Metin,
I seem to remember you need a free plugin called ScatterVL. I just did a search and found a few threads.
Dan
Metin,
Volume lights will work, but they only seem to work with shadow map
Thanks very much guys. I noticed that VRay shadows also don’t work when using an other light that lights the scene with a projector map.
Cheers,
Metin
And another tip: if you’re using fog in your environment as well, as I do, be sure to set the atmospherics to the right order. The volume light suddenly appeared after exchanging its queue position with the fog atmospheric.
Cheers,
Metin
