Hi.
I’m testing the volume material, a mere fog effect. Even though I follow the correct procedures, I can not make the result appear. Do you know any problems with the latest version released for Mac (2017/10/04)?
Decrease the distance
start with low about 2500 and work your way up
( double check its ticked in the scene environment )
There is currently an issue with the Global fog material in recent builds (the ones with IR). I’ve reported it on Mantis - the Volume material on objects still works though (just be sure the camera clipping plane is outside the fog object). Once all is up and running as expected again, be sure to check the helpdesk article on the topic - https://help.c4d.corona-renderer.com/support/solutions/articles/12000035577-how-to-use-volumetrics-
