I’m starting to use Corona and I love it !
However I’m trying to load a VDB in corona volume grid but nothing happens , the volumegrid simply keeps saying “no data loaded” although I tried multiple times in different scenes.
Is there anything I’m doing wrong.In the statistcs ,under volumegrid parameters ,it says “unable to load fire.vdb”
Works for me, attached after some small tweaks just for appearance (changed to channel mapping, used autoscaling in the Channel color mapping, lowered the scale) Corona 4 Daily Build Jan 10th.
Shouldn’t be, the only change in the daily builds relating to the CoronaVolumeGrid is “Fixed occasional flickering of CoronaVolumeGrid when using velocity-based motion mblur”.
EDIT - here’s what my statistics look like on loading, what does yours show?
