While transitioning from Maya to Houdini we have noticed, that some of the options/features of the VolumeGrid in Maya seems to be missing in VRay5 for Houdini.
Some of the missing options are:
- Constant Color
- Simple smoke opacity
- Based on dropdown for Color and Opacity
- Channel mappings?
We tried to simplify the UI as much as possible, taking other artists’ feedback as a guide.
Here’s how those options exposed in the Maya UI relate to V-Ray in Houdini:
Constant Color → this is the same as removing one of the color swatches so the Smoke → Color Ramp has a single color.
Simple smoke opacity → this is the same as keeping the Smoke → Opacity Ramp at it’s default value and setting the Source Range parameter to reflect the Density field range.
Based on dropdown for Color and Opacity → those options are in the Bindings tab, under Smoke → Opacity Field and Color Field.
Channel mappings → because of the above, those are not needed - you can simply specify the field you want to use under the Bindings tab.
Futhermore, please use the File SOP (in Packed Disk Primitive mode) to load VDBs - we’ve recently restricted the Volume Grid Cache SOP to be used for “.aur” files (Chaos Phoenix cache files) only.
Hope that helps!
edit: I just realized we’ve missed this thread a couple of months ago and you’ve received no answer - please accept my apologies for that.
