Volumetrics ignores opacity
Hi guys,
I was placing some plants to my project and there is a plant with a stem and leaves. The stem has some volume but leafs are just planes. There is one texture for whole plant - the stem and leaves. I could use translucency for leaves, but it would be incorrect for the stem. So I have decided to use Volumetrics channel. The problem is that as soon as I choose some distance to pass through in the volumetrics channel it ignores the opacity channel on the leaves. This needs to be fixed.
Is there some solution right now?
Kind regards
can you share the scene with us? I would love to have a look into it and see if I can come up with some solution.
Thanks,
Jan
Here is the file.
Volumetric Opacity problem.c4d (1.22 MB)
Could you also add the textures? :smiley:
Thanks,
Jan
