Volumetrics - include/exclude
Any ideas how to exclude lights from participating in volumetric fog rendering?
I still want them to affect the scene but only render volumetrics with the selected lights.
Thanks,
Are you using global fog or a box/other object with fog material? In case of object, you could probably exclude that object from a specific light.
I was using the global fog method but will try the box method you suggested.
Thank you,
I have varying luck with this. I can still see some lights in the volume that have been excluded from the geometry on which the volume is applied. I can’t figure out why.
Can you post some image, or even better a scene, showing this?
Hi, same issue here, with pictures and scene :
https://forum.corona-renderer.com/ Exclusion Issue in CoronaLightMtl
