im doing work for volvo but having problems with the model they sent me, they were from lightwave exported to 3ds…and 60% of the surfaces is missing…anyone here have volvo new models…
have a look on Turbosquid,they should have lots ![]()
they have quite a few but at usd140 each…and its last years model..
thanks nat..
could it just be that the surface normals need flipping?
i did that and even use double sided shaders and render set but still…i think it was exported poorly by a third party software..
anyone know any good object converters from lwo to 3ds?
You can do it in formZ.
It opens" Lwo." and it can export to “3ds”.
It works fine for the model only (not the textures).
thanks…ill find someone here with form z…appreciate it very much..
u can use silo
u can import there save the work as .3ds and export to max if the cars are poligons of course
just to add… .3ds file format has a face limit per object of around 32,000 or something close to that, so parts are probably missing because they had too many polygons.
you might want to try importing them as something other than .3ds
.obj is a good one for polygon models. a free import filter for max is available from www.habware.at
rhino is great for import/export. it works with just about any format.
sean
Use polytrans. The best converting app ever!!!
thanks guys,it turned out that they exported the model to 3ds using a trial use software that deletes every 5th polygon,thanks again.
man…it almost sounds like a cruel joke…
paul.
heheh the first thing that i though was that they used a dodgy exporter that remove the polys. But i decided to stay quiet…but damn thats CRAP.
hahaha who does that and doesnt notice…LOL
