VPN and 64
I am running XP 64 and I can no longer VPN using Cisco. I tried logmein, but it isn’t working for me… When I login using logmein I see MAX, but my stage is my desktop, which is odd. What are you guys using to remotely access your machines under XP 64?
im using vnc
VNC
are you tunneling through a firewall?
hmm. nope
I am using logmein on xp64 at work with no problems at all!
Logmein
MAX 64 and XP 64?
if your seeing your desktop, its because its not showing the proper video hardware accelaration. I have seen the same in VNC as well. And you need the video hook driver installed… or was it uninstalled.. cant recall.
It could be similar with that software. Its not your firewall thats doing it. As you HAVE the connection. Its something odd in the software.
