Hi all. Whats the best way to get renders I have done in Corona into VR on the Oculus and also for 360 panoramas to upload them on the web. Do I need to buy another software or is something like unreal engine best for this. Any advice is much appreciated. Thanks.
Hi there. Hopefully, this article will help you:
https://help.c4d.corona-renderer.com/support/solutions/articles/12000044340-how-to-render-a-360-spherical-image-with-corona-renderer-in-cinema-4d
Many thanks, I’ll check it out.
I have been rendering some 360 tours now and it’s quite easy with corona. After some experimenting to get the optimal resolution for oculus go, I was set to go
I just didn’t think it was easy to get/copy the 360 images onto the oculus, especially for the clients, so I ended up with a subscription at www.THEVIEWER.co you should look into it, it’s a great tool.
A new feature there, that i haven’t used yet, is the zdepth map integration for more fluid warping from point to point
if someone has a tip or workflow to quickly render the zdepth map for a 360 project in coronac4d, I’m very interested to know how…
Thanks for the info, I’ll take a look at The Viewer. I was also looking into what the Adobe suite can do and found that Adobe Animate can do 360s.
