We have been noticing the resolution of VR with Oculus Rift drops tremendously to cause vertigo when a user tries to navigate through the model. Is there a setting I need to adjust so the VR doesn’t jitter and it’s as smooth as a walk through. If not, I recommend if your team improve on the VR experience. It would be great if this gets fixed in the next release.
Thank you!
Vertigo describes the effect of a simultanous translation and view angle change. The view angle stays constant durimg VR so the nausea must be triggered by something else like a low frame rate. Can you try it on a stronger machine?
A low frame rate might be the reason. We have a razor blade when we were running VR. The model doesn’t render fast enough and causes the effect.
