VR Headset compatibility
Just a quick question, I’m looking into other headsets for VR, and one is the Pimax headsets. For example the 5K PLUS VR Headset, or Vision 8K, but for that I’d definitely need to upgrade my graphics card too, but that is besides the point. It seems it also uses Steam VR, at least as a base. Will this be compatible with Enscape VR? I’m still doing research but thought I’d ask here in the meantime to start getting bases covered.
Thank you for any assistance!
I’m afraid, while I can say that Steam VR headsets should be working with Enscape, we did not have the chance to test those mentioned headsets, yet at least. This means we cannot 100% guarantee that it will work, but perhaps you will be able to order from a store with a decent return policy if you want to give it a try. :slight_smile:
Thanks for your reply! I suspect it will work, since it also seem to use Steam VR as the base. Which should translate fine. However, if I do test it, I will let you guys know if it works or not.
That would be great, thank you in advance!
