VR headset not connecting
Hey Guys,
Anyone had issues connecting HP VR headset?
I’ve downloaded steam, all updates are current but still not working.
Cheers,
Hey @Bowerban , welcome to the forum. :slight_smile:
In order to run Enscape with the HP VR Headset or any other Windows Mixed Reality Headset, the following software needs to be installed and running: Steam, SteamVR and Windows Mixed Reality for SteamVR. Could you please make sure to also install SteamVR and Windows Mixed Reality for SteamVR?
Also, don’t hesitate to check out our Virtual Reality Headset knowledgebase article for even more information about this subject in general.
I am having the same issue. Searching for Headset. I have SteamVR and Windows Mixed Reality for SteamVR installed. When the headset is connected to my laptop it automatically defaults Windows Mixed Reality for SteamVR. I open Revit start Enscape and select VR and all I see through the headset is Windows Mixed Reality for SteamVR portal. Enscape does not recognize my Headset.
All good now, Was confused on the default windows platform versus Windows Mixed Reality for SteamVR portal. As per above you need to install Windows Mixed Reality for SteamVR portal in order for it to work.
Hi , So you did not launch the enscape portion in the headset but instead launched it through Steam Vr portal ? Can you explain that ?
