Hi all,
I may be missing an option but is there a way to hide the menu on the left hand when using Enscape VR? (the one with the time of day slider, scenes etc on it) Its quite obtrusive so would be good if I could turn it off.
Hi all,
Hi @BarryFishFinger and thanks for your inquiry.
It’s currently not possible to hide that menu in VR through a setting or so, though in that regard I often recommended before to just simply lower your left arm (to around hip height) until that menu isn’t visible anymore in your direct perspective when looking ahead.
If this still presents a problem, or you’d simply like this as an option in any case, feel free to also forward this as a feature request to product management itself directly using our roadmap portal.
Thanks @Demian_Gutberlet I have submitted as an idea. Also to have walk mode enabled by default when switching scenes, my users I’ve been testing VR on that are less confident are teleporting through walls often before I can get there and enabled walk mode on the handset.
