VR mesh export problem
I select an object in my scene. Right click and choose vr mesh export. In the Vray mesh export dialog box I specify the folder. For example G\Data\Max\Mymesh\Onyx\Onyx_Broadleaf.
I specify the name of the file MyTree01
The vrmesh file should be created as MyTree01.vrmesh inside the folder G\Data\Max\Mymesh\Onyx\Onyx_Broadleaf.
Instead the vrmesh file is created as Onyx_BroadleafMyTree01 inside the folder G\Data\Max\Mymesh\Onyx
I have tried a number of things here but the vrmesh exporter seems to always add the last folder name to the front of the file name and save it in the folder one level up.
It seems like a simple process but… Am I doing something wrong? Can anyone else check to see if this is happening to them?
Using Max design 2010, Vray 1.50.SP3a 64 bit
TIA for any help!
Yup, I have the same problem. Im on max 9.
Thanks for your reply. Is this a bug? Is there a fix? Anyone else know of this problem?
